Tromox Mino
deadropine
Roller: Tromox Mino
PLZ: 8
Re: Tromox Mino
Beitrag von deadropine »
Thanks!
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
Beitrag von vlad_vy »
deadropine hat geschrieben:
Mo 10. Okt 2022, 16:56
I have seen that Niu has a handheld diagnostic tool which (Niu handheld H1) they connect to the charging port in order to change settings. Can the CAN bus system of the controller be used for programming?
If controller software support it. I have seen two *.bin files for NIU, they look like encrypted, so can be flashed over CAN (NIU use RS485) bus only.
deadropine
Roller: Tromox Mino
PLZ: 8
Re: Tromox Mino
@vlad_vy
I am not really familiar with ultra edit and foc files. How did you open or convert the foc file to something readable? I only see strange symbols. £¥$¿•¡*£{}$??????
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
We have different settings or different versions of UltraEdit. My old UltraEdit-32 (v12.00) open *.foc file always in binary mode. Try open *.foc file, then "Edit"->HEX Functions->HEX Edit. You have to see something like:
00000000h: 31 32 33 34 35 36 37 38 39 70 72 66 0D 0A 06 07 ; 123456789prf...
Probably you will need switch to "Edit"->HEX Function->HEX Edit\EBCDIC and back to "Edit"->HEX Functions->HEX Edit. Or try use binary compare, you can do binary edit at result windows.
To binary compare two files use: "File"->Compare Files, select two files to compare, select "Compare Options" -> Binary, "Editor Tiling" -> Tile Vertical.
deadropine
Roller: Tromox Mino
PLZ: 8
Re: Tromox Mino
@vlad_vy
Thanks for your support. I will give my best!
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
My "Start" button is not waterproof. :(
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
Tromox MIno "Start" button.
deadropine
Roller: Tromox Mino
PLZ: 8
Re: Tromox Mino
@vlad_vy
I have opened the foc file and see all the lines. My problem is the part on the right side next to the semicolon. There I cannot see the parameters you have found. There are just strange letters. How did you convert them into the usable information you have posted? Especially the 0000h -0100h lines.
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
You don't need the third column, it a pure binary file without any comments and structure. At first assume it consist from 16 bit values (two bytes, left MSB and right LSB), then try to convert the value to decimal. Use Windows Calculator at programmer view. Select hexadecimal, select 2 bytes, enter value, then switch to decimal and write the value.
Any value started from F (bit 16 = 1), for example FF 9C, most likely is negative, FF 9C = -100
If you did not get reasonable value, most likely it is 1 byte value, for example:
0106h: 6E : High-Speed Percent (110)
0107h: 43 : Middle-Speed Percent (67)
0108h: 3C : Low-Speed Percent (60)
0109h: 32 : Fourth-Speed Percent (50)
010Ah: 32 : Speed Limit Percent (50)
010Bh: 00 : ???
Zuletzt geändert von vlad_vy am Fr 14. Okt 2022, 08:07, insgesamt 1-mal geändert.
deadropine
Roller: Tromox Mino
PLZ: 8
Re: Tromox Mino
@vlad_vy
Respect! Thanks for your lesson in informatics.
Zurück zu „Tromox“
