Lingbo Controller einstellen
Kadett 1
Roller: BMW CE 04 15KW
PLZ: 555xx
Tätigkeit: Rennfahrer ;)
Re: Lingbo Controller einstellen
Beitrag von Kadett 1 »
Hello,what Software do you use? Can you Upload it Here? My Interface is in chinese.
Kadett 1
PLZ: 555xx
It Looks like your second battery cable is connctet...
gundaf
Roller: City Twister 6.0
PLZ: 63***
Beitrag von gundaf »
@yashwanthnu: yes it would be great to get the Software v5 in English, pls. provide
did the motor run ? or is he like dead? try to turn it a little bit by hand.
@ Kadett1: I've got the CN Controller Lingbo 72252 yesterday
now my first experience:
Self learning isn't working like it should
After bring in my settings, the engine is running, but the RPM are low ~ 780-800 rpm (depends on the battery status).
Top speed (GPS - Speedometer w/o function and Mode also on "P") = 63km/h, with the Original controller I have a top speed ~70-72 km/h.
in my opinion the engine can easily go up to >1000 rpm, but all setting I changed --> no impact.
how you did solve this challenge?
Kadett 1
PLZ: 555xx
How much Volltage du you have?
gundaf
PLZ: 63***
60V
Kadett 1
PLZ: 555xx
Wich Motor do you have ? I have 60v 3kw Bosch 12" Motor and it is the Same. With wrong settings -120° Shift and Reverse setting it has more RPM about 900-950 .Sound and Torque are bad but I have to deal with it until my 72v Battery arrive.
gundaf
PLZ: 63***
LUQI, CN Brand 13“ 3KW 60V
I‘m in contact with my chinese friends, but till now no solution, only to increase peak to 300A und current to 100A …. no change, and I fear to overload the motor
Let’s see what is the next proposal from them
We will not give up !
Kadett 1
PLZ: 555xx
My Battery BMS only accept 65 A . With 100 Ampere i fly to the moon. :lol:
gundaf
PLZ: 63***
Bisschen gespielt :roll:
Kadett 1
PLZ: 555xx
Ich behaupte mal mit 60v geht nicht viel mehr. Ist das Flux weakening aktiv :?:
