Neuer Batch Tank
PLZ: 41564
Neuer Batch Tank
Beitrag von Evolution »
The 6 KW batch tank from zero is now available for the model model 2015 and newer zero s / SR-and zero ds / DSR MODELS.
The 6 KW batch tank is compatible with the public transport systems and home stations of type 2 (230 v). To reach the maximum charging, close the standard charger together with the batch tank - for a total throughput of 7,3 KW. This corresponds to a range of approx. 160 km per charging hour.
Examples of loading times:
- Standard Charger Zf14. 4: 9,8 hours (100 % charged)
- Zf14. 4 6 KW batch tank: 2,5 hours (100 % loaded)
- Standard Charger Zf14. 4: 9,3 hours (95 % charged)
- Zf14. 4 6 KW batch tank: 2,0 hours (95 % loaded)
The batch tank is an accessory designed by the dealer and can not be installed on a motorcycle with a power tank from space space. Even if the body of the batch tank does not match the model colors 2015-2016, you can take this opportunity to renew the appearance of your motorcycle. Just share with your dealer if you want to order the matching rear and front fender body.
most
PLZ: 30519
Re: Neuer Batch Tank
Beitrag von most »
Moin, da ist nie wieder was drüber gekommen, oder? In der 2020er Pressemappe findet sich kein Hinweis - nur wie zuvor auf Charge- und Powertank.
Energica Experia 2023 Bild
LiveWire S2 Del Mar 2024
Brammo Empulse R 2013
Zurück zu „Zero“
