CSC Motorcycles City Slicker
PLZ: 41564
Beitrag von Evolution »
Die amerikanische Firma CSC Motorcycles bietet den China-Import City Slicker an, der mit folgenden Werten antritt:
STANDARD Features Include:
Wheel Base: 49.2 in
Turning Radius: 13.1 feet
Seat Height: 30.0 in
Weight: 216 lbs
Maximum Carrying Capacity: 330 lbs
Front Inverted Telescopic Fork, Rear Preload Adjustable Monoshock
Front 110/70/12 Tire, Rear 120/70/12 Tire
Front Twin-Piston Hydraulic 8.5 in Disk, Rear Single-Piston Hydraulic 7.5 in Disk
Regenerative Braking
Motor: 3.2KW Peak Power, 1.5KW Rated Power, Swingarm-Mounted, Brushless
Reverse Drive
Battery: 72Volt 30AH Lithium Ion
Charging Time: 6-8 hours
Charging Voltage: 120VAC
Battery Replacement: Key Lock, Replacement Time Under 2 Minutes
Instrumentation: Speedometer, Odometer, Tripmeter, Battery Status, Park Indicator, Reverse Indicator, Low Battery Warning, High Beam, Turn Signals, Power Mode Indicator
LED Turn Signals
Left Handlebar: Turn Signal Switch, Hi/Lo Beam, Hi Beam Flash, Horn, Rear Brake Lever
Right Handlebar: Throttle, Lights, Mode Selector, Park On/Off, Front Brake Lever
Dash Cluster: Reverse Selector, Trip Meter Reset, K/M Selector, Onboard Diagnostics Display
Key Lockable Luggage Compartment, Battery, Forks, Ignition
Top Speed: 46.6 mph
Range: 37 miles at 37 mph; 62 miles at 20 mph
Colors: Red and White, Blue and White
Warranty: 12 Months, Unlimited Mileage
https://www.cscmotorcycles.com/default. ... wInventory
