Solution 2 will be a good way.
I have done this with two cars, while changing from 288mm solid rotors to 308mm floating rotors.
Bremsen E Abs
- PLZ: 79
- Tätigkeit: Elektromeister
Re: Bremsen E Abs
Masini Extremo Neuaufbau 2021 7,7kwh Li-NMC Fardriver ND721800 400bA 1400pA
42-58,5V CC/CV Netzteile/Lader mit 1-4kW zu verkaufen 0,65-2,2kg klein, leicht, langlebig
- Miguello80
- Roller: E-Odin 2.0 6kW AMR
- Land: anderes Land
Re: Bremsen E Abs
What do you think about this ? Chinese, but floating = should not suffer to warping like classic discs. Yyeah, buttons can get stuck over time but it is easy to clean them. But still 300 mm (grinder will solve it) + possibly need to buy new bolts..
https://www.chinesemotorcyclepartsonlin ... rt/BRDF031
- PLZ: 79
Re: Bremsen E Abs
Not all chineese things are bad.
Just try it.
Just try it.
