Increase speed silence s01 49cc
S01, S02, S03, Mó
Djfumon
Roller: Silence s01 49cc
PLZ: 46020
Land: CH
Re: Increase speed silence s01 49cc
Beitrag von Djfumon »
Pfriemler hat geschrieben:
Fr 21. Feb 2025, 17:51
PAGE2 -> block "Three-speed"
As in the default settings, % are nearly the same as km/h, set the value in the left column for different modes, Low(%) = ECO, Mid(%) = CITY, Hige(%) = SPORT. You should read 31/50/50 per default, set to 40/70/100.
Read https://www.elektroroller-forum.de/view ... 80#p385080 for a full comparison of low and high speed settings.
Be aware of legal consequences. If you do so, it's on your own risk. We neither can prove that the S01 LS will behave like the HS version nor that this may not cause severe technical issues.
Watch the OBD (engine) fault, it should get off after the 5th restart. If not, and if you have any OBD diagnostic hardware (for cars etc), try to read the engine fault. I get a P1019 when it's getting cold, without any damages or loss in drive capabilites.
Hello mate,
Is there a configuration that uses less battery? I'm going to work as a delivery driver and I need it to last as long as possible
Very thanks for you help.
Rudi Ratlos
Roller: Seat Mo 125 (2022)
Beitrag von Rudi Ratlos »
Djfumon hat geschrieben:
Fr 21. Feb 2025, 19:13
Yeah, of course. You can decrease the value of "Current-Limiting" on page 2 down to zero. The less you set this value the less battery will be consumpted...
Pfriemler
PLZ: 14513
Tätigkeit: Tonkünstler
Beitrag von Pfriemler »
Rudi Ratlos hat geschrieben:
So 23. Feb 2025, 11:42
This will work definitely, but with more or less restrictions in terms of driving comfort. I stopped fiddling with it after a test with the identical route through the city on two consecutive days, once ECO and once SPORT (with very moderate throttle control, without senseless accelerations), with recharging at the end of each day. If I remember correctly, I even recharged a tiny bit less after the day with SPORT. In other words: there are no more economical settings, only an economical driving style.
Djfumon
PLZ: 46020
Land: CH
Very thanks to all for the help.
Zurück zu „Silence / SEAT“
Mitglieder in diesem Forum: Google [Bot] und 19 Gäste
