Rezon Bohemia
- bikemite
- Händler
- Roller: Bimie Ebroh Horwin Niu Tinbot
- PLZ: 1130
Re: Rezon Bohemia
`Naja es scheint schon so, dass die Bohemia einige Änderungen gegenüber der Alrendo haben wird, die ein neues Modell/einen neuen Bereich rechtfertigen würde. Allein die Dimension und der Rahmen wird wohl gleich bleiben... Aber mal abwarten, wie du geschrieben hast...
Bimie: Gioco, Grazie, Sorriso, il Primo, Pico, Tigre
Ebroh: Bravo
Gowow: Ori
Horwin: EK3, SK3
Next: NX2
Niu: NQiGT, NQiSport, MQi+, MQiGT
RFN: Apollo Ares
Tinbot: Esum, Esum Pro, RS1
Trinity: Panthera
Wow: 775
Ebroh: Bravo
Gowow: Ori
Horwin: EK3, SK3
Next: NX2
RFN: Apollo Ares
Trinity: Panthera
Wow: 775
- PLZ: 67166
Re: Rezon Bohemia
Habe Mail bekommen
Die Vorführer sollen Ende Mai kommen
- vaderAT
- Roller: ZERO SR ZF15.6 2023
- PLZ: 8010
Re: Rezon Bohemia
We have had a lot of questions about the on-board charging unit fitted to the Rezon Bohemia. It's time we cleared up some information about it.
1. Yes it does charge as both DC and AC chargers
2. The maximum charge speed is 6.6kw when using either DC or AC Charging. The DC charging function is to allow you access to more of the charging network so you will never be stranded. It is completely optional and for riders in certain countries, you'll probably never even need to use it if there's enough AC chargers.
3. The DC charger is simply a larger DC-DC inverter. It's not complicated, it's actually a pretty simple tried and tested technology. It simply steps down 260v to 100v.
4. A 12kw charger is not possible because it is absolutely huge and would not fit inside the frame of the bike. We do sell motorcycles, not cars so size takes a much more important part in our design and limitations.
I hope this clears up all of the questions we have had and gives everyone a better understanding of what we are offering.
- PLZ: 67166
